Manufacturer Certification for ASTM pipes
If I need to know if a manufacturer is qualified or capable to produce ASTM standard pipes (A106, A312, etc.), are there any certifications that the manufacturers should have? As I know, for API pipes, the manufacturers have certificates from API to use their monogram. Furthermore, what's the best way to determine that a certain manufacturer is capable of manufacturing pipes as the ASTM standard, without testing samples or finished products.
The purpose is to see whether or not a manufacturer is allowed to participate in a purchase tender that we will conduct.
Thanks for the help!
RE: Manufacturer Certification for ASTM pipes
The link below contains the Lloyds Register of Approved Manufacturers of Steel Pipe and Tube (Worldwide)
Maybe of some assistance,
DD
https://www.cdlive.lr.org/information/documents/ap...
Thanks for the help.
cvg,
Do you mean that I should just ask the manufacturer? I want to make sure they are a good manufacturer that can make good products as per the specs. I can't just ask them that.
Anybody else have any ideas?
