Relocating nx502_Threaded_Hole_Standard.xml to Shared Network
I would like to locate the nx502_Threaded_Hole_Standard.xml file to a shared network so that I can easily edit it from one location to eliminate distribution to downstream users. How is this possible as I don't see this in the ugii_env.dat file?
Matt
RE: Relocating nx502_Threaded_Hole_Standard.xml to Shared Network
Never mind. I think I found the environment variables to add:
6.Set the environment variable to specify the location of the customized data tables.
◦UGII_SCREW_CLEARANCE_HOLE_STANDARD_DIR
◦UGII_THREADED_HOLE_STANDARD_DIR
◦UGII_DRILL_SIZE_HOLE_STANDARD_DIR
