What is a typical valve train after leaving the LACT unit.
I have a typical 4" flange leaving the LACT Unit and would like to know what the typical valve train set up will be after the flange.
RE: What is a typical valve train after leaving the LACT unit.
Isolation valve and non return valve?
Why do you ask?
It probably will vary depending on the end users requirements. Tank, railcar, pipeline, etc.
Does LACT = "Lease Automatic Custody Transfer (automatic transfer of ownership of crude oil)"?
Sometimes its possible to do all the right things and still get bad results
