I recently got NX9 and I'm having trouble exporting my PART files into any other format.
Hey guys,
I need some help with NX9. I recently got NX9 and am completely new to it. The menus look similar enough for me to do some basic things, such as exporting, but when I tried exporting my files, it wouldn't appear where I exported it to. No files appear in the folder I designated. Why is this?
- Kozen
RE: I recently got NX9 and I'm having trouble exporting my PART files into any other format.
Does your license support exporting to this format (have you exported to the same format in a previous version of NX)?
www.nxjournaling.com
I'm trying to export to STEP and IGES.
I've exported to these formats in previously (NX 8).
- Kozen
Whats written in this window should be stored in a logfile, in the same directory and the same name as the step/ iges file.
example
the_model_123.stp ( which is missing)
the_model_123.log ( this is the logfile)
Open the logfile and read , it will probably note why the export fails.
Tomas
To Toost: I probably should've mentioned this earlier, but no log files are created. Which is strange because I've already double-checked the destination of my files and it's not wrong. Both the new format of the file and the log file should appear in the folder I designated, but they do not.
To Cowski: I checked the designated destination folders for my exports and they're good. I've sent files to these designations before with NX8. I also just checked the Customer Defaults -> Gateway -> Translators and checked every tab if they indicated any new export designations and they're all blank.
- Kozen
Who installed NX? Did the user have full admin rights or was User Account Control turned off?
If UAC wasn't turned off was the install run with 'Run as Administrator'?
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
NX8 had no problems with this issue, however...
Problem solved, though!
- Kozen
