problem with Macros and Drafting
I've been recently programming macros in VBA, and have found the following problem:
I wanted to do a macro which automatically calculates the plane coordinates ( B2, F5, etc...) of a determinate object (i.e: a text).
To do this, I needed to calculate the object coords with respect to Sheet's origin. These are (I thought they were) the result of adding two vectors: the View's origin with respect to Sheet's origin vector plus the Object's origin with respect to View's origin vector (some kind of absolute+relative coords).
So, here's the problem, object's coordinates are taken with respect to the View's blue axis system (which is the 3d solid's axis system), but the View's origin with respect to Sheet's origin vector doesn't point to the blue axis system!, but to an invisible, unreachable point which seems to be the center of gravity of an imaginary bounding box enclosing the 3d solid (weird!!).
After many hours wasted trying to get it, I found an annoying, user-unfriendly solution (which is so annoying and user-unfriendly that I won't explain it here), but I would be very grateful if somebody knows how to help me with it.
Thanks for all.
Nimdraug.
Thanks for all.
Nimdraug.
