Signal 11 error when attempting multiple restarts of a co-simulation
I need to use co-simulation in ABAQUS to solve my problem. Additionally, my simulation contains many (approximately 200) steps. Since co-simulation can only be used in a single step, I'm using the restart option to restart the simulation at the beginning of each step. When I began my third restart simulation, I received an signal 11 error. This seems strange because the initial simulation and the first two restart simulations worked fine. The only thing I'm changing during each step is the temperature field, so all steps are essentially the same (just different temperature values). I initially thought that maybe my temperature file was corrupt, so I tried other temperature files, but I keep getting the same error. I'm using ABAQUS 6-12.1. I'm running the simulation over multiple processors, but I continue to get the same error if I try running with a single processor. Does anyone have any thoughts/suggestions?
Daniel
Daniel
RE: Signal 11 error when attempting multiple restarts of a co-simulation
I am new here.
I am running an fsi co-simulation in abaqus. But I dont know how to restart one using command line option.
If it were a normal analysis, one could reference the old and new job in the command. For an fsi, there are two odbs. How do we go about writing the command to restart the co-simulation.
Thanks...
