Quench rates & methods 6061 Aluminum Tube
Hi there,
I am new to these forums. I am working on an R&D project and have what I think is a simple question but I CANNOT seem to find anything clear. I am forming aluminum tubes and need to determine the quench rate and method (water - ambient, boiling, etc, molten salt, air, etc) to give the best possible tensile strength for that grade. Can anyone help me? The tube is 100 mm OD, 970 mm long, T=3.7 mm
The purpose of the project is to change the material grade from 5052 to a 6xxx series (to reduce cost). I am thinking a 6061 or 6063.
Thank you!
Thank you!
RE: Quench rates & methods 6061 Aluminum Tube
Good free references would be Mil-Hdbk-5J and Mil-H-6088G which can both be found here Link
http://www.aec.org/assets/pdfs/webinars/aec_therma...
http://metaljournal.com.ua/assets/Uploads/attachme...
https://engineering.purdue.edu/BTPFL/BTPFL%20Publi...
