NX 7.5 IDENTIFICATION SYMBOL
Hi I need a a VB Script in Order to filter TYPE IDENTIFICATON SYMBOL>>> SUBTYPE>>> Triangle Point Up-Identification Symbol
in all the Sheets of the Drawing and delete it. Please Solve this.
RE: NX 7.5 IDENTIFICATION SYMBOL
CODE
Option Strict Off Imports System Imports System.Collections.Generic Imports NXOpen Module delete_ID_symbols Sub Main() Dim theSession As Session = Session.GetSession() If IsNothing(theSession.Parts.Work) Then Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "Delete ID symbols: triangle up" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) If workPart.Annotations.IdSymbols.ToArray.Length = 0 Then lw.WriteLine("No ID symbols found in current work part") Return End If Dim triangleUp As New List(Of Annotations.IdSymbol) 'loop through all the ID symbols in the part For Each tempID As Annotations.IdSymbol In workPart.Annotations.IdSymbols Dim oldIdBuilder As Annotations.IdSymbolBuilder oldIdBuilder = workPart.Annotations.IdSymbols.CreateIdSymbolBuilder(tempID) 'type of symbol to change If oldIdBuilder.Type = Annotations.IdSymbolBuilder.SymbolTypes.TriangleUp Then triangleUp.Add(tempID) End If oldIdBuilder.Destroy() Next Try theSession.UpdateManager.ClearErrorList() Dim markId2 As Session.UndoMarkId markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Delete ID symbols") Dim nErrs1 As Integer nErrs1 = theSession.UpdateManager.AddToDeleteList(triangleUp.ToArray) Dim nErrs2 As Integer nErrs2 = theSession.UpdateManager.DoUpdate(markId2) Catch ex As NXException theSession.UndoToMark(markId1, undoMarkName) MsgBox(ex.Message) End Try lw.Close() End Sub End Modulewww.nxjournaling.com
