Do your CAD designs comply with RoHS?
I don't know whether to file this here or in Pat's Pub, or under CAD somewhere. Not poisoning people seems to be ethical.
Does this Machine Design article read as weirdly to you as it does to me?
My product, documented with SolidWorks or some other 3D CAD, must meet RoHS. I suppose that if I attach the code "ROHS" to my filenames, you can scan down the assembly tree to see that all components comply with the standard. This does not protect the public, or you. Printed circuit boards and wiring probably are not designed and controlled within the 3D CAD. External vendors may claim that their products comply with RoHS, but your QA may know better. If you are not in control of your finalized documentation, someone way make modifications that take your product out of compliance.
I do not see a CAD management issue here. This provides some dull, stupid person a set of rules to follow, that may or may not work. You are in compliance with RoHS or any other standard if...
- You did your job competently as a designer.
- You control the documentation. Manufacturing and sales can write ECRs. You decide what to do about it. Since you prepared a complete, high quality documentation package, there no danger control will be taken away from you.
- Your documentation specifies the RoHS requirement everywhere it matters - on manufacturing processes, on specification controls, etc. Changes that violate RoHS are clearly recognized at the source.
- QA has the authority to reject parts and processes that do not meet the standard.
JHG
RE: Do your CAD designs comply with RoHS?
> have a "ROHS" compliant CAD design, since that's all electrons and magnetic or charge domains in memory
> have a traceable document trail that proves your CAD design will implement ROHS compliance. How does anyone know from the CAD drawing that a particular surface treatment or component is ROHS compliant?
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Dan - Owner
http://www.Hi-TecDesigns.com
CAD model, not document!
JHG
Although in this case it's not very informative. And I wouldn't contract with the company to provide this service based on this article.
The CAD model only goes so far. Your procurement system must maintain the DOCUMENTS, such as SOW and spec, that carry forth the CAD model into the procurement itself, and then into the delivery documents like CoC.
TTFN
That said, back in 2006 ish we did tweak some standard drawing notes to address ROHS.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Similar to Kenat, we made the RoHS notation a part of our standard title block, and our vendors know that they'll be dropped like a hot potato if a spot check ever fails lab.
Agreed, a drawing noting the items you list is usually preferred and included, but it is not mandatory to meet ASME specifications. All of that information can be carried in model space.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Somewhere, something has to be written down, and a form that can be reviewed by engineering and access by purchasing. A rectangular 2D drawing provides ample room for notes specifying RoHS or whatever other specification matters to you. You can add RoHS compliance to the metadata of your 3D model. This can be used to populate your ERP BOM. Otherwise, this information is hard to access without the 3D CAD software or a viewer. When you communicate through computers, the you look for the lowest common denominator. In most offices, that is Microsoft Word and Adobe PDF.
We are not talking about minimum compliance to a standard. We are talking about not screwing up.
JHG
Like I said though, for the unwashed masses some level of drawing is probably going to be required for a while yet.
I do not disagree with what you are stating, just disagreeing that a drawing is MANDATORY (per ASME). There are many programs out there that unify integrated supply chains, but it requires commitment, investment and effort by all parties involved to make the system work without drawings.
3D viewers are becoming quite common, inexpensive (even free) and getting better all the time.
(Thanks for covering my back, KENAT!)
-Dalai Lama XIV
A lot of this seems to be the same issues as details on construction drawings and whether there was a traceable means of telling whoever assembled / built / manufactured the widget that they needed to do something.
The OP correctly alludes to the consideration that unless there's some sort of verification process, then RoHS by itself doesn't mean much. Disclosure gets fun when it gets established that lowest bidder / tenderer noted that their equipment wasn't compliant and someone agreed to deviate from the specification / note / standard.
