Material design - Hardness and thickness in compression of Silicone rubber
I'm trying to understand the relation between Hardness/thickness of silicone to compression/deformation.
In order to design the material, if I have a constant compression stress on the silicone i would like to know how the change in the hardness will effect the thickness.
Thanks!!!!
