how to merge nodes on two co planar faces in Ansys WB ???
I am simulating fracture problem. for that, i split a body into two bodies with slice by plane. that gave two faces at same location (at intersection of bodies). Again, i split faces on each body at intersection into two faces with a sketch edge. Now, i have four faces at intersection(two faces on one body and two faces on other body). after meshing it i want to merge nodes on two faces(one face on one body and another face on another body). how can i merge nodes on two faces that exist in same location in ansys workbench???
(For my problem i cant use form parts in DM)
So, finally i need help on merging nodes on two geometrically similar faces at same location (coplanar faces).
RE: how to merge nodes on two co planar faces in Ansys WB ???
Maybe using nummrg in WB is bad? I think I can recall a situation where it caused problems for me when using WB ver. 10.
Maybe coupling your dofs together using is a better option? The procedure is the same as outlined above.
Hope this helps
/PB
This cannot be achieved with APDL. Once the file leaves workbench and enters into Mechanical APDL, you have no access to the underlying geometric entities created in Design Modeler or SpaceClaim. In mechanical APDL, you have access to nodes and elements only. VGLUE is a pre-processing command intended to be used on geometric entities created in Mechanical APDL pre-processor /prep7, it will not work the way you describe in your post.
/PB
