beginner in Fortran77
i just started learning Fortran 77 language, (i have already some programming knowledge in C and Pascal but i need to learn fortran 77 for use in other programm which is based on this language). So i started learning it using a book called "Fortran 77 and numerical methods by C Xavier". There i wanted to test some simple programs, for example this programm for calculating triangle area:
C Program for area of triangle
write(*,1)
1 format(1X,'type the sides A, B, C')
read(*,2) A, B, C
2 format(3F10.3)
S=(A+B+C)/2
Area=SQRT(S*(S-A)*(S-B)*(S-C))
write(*,3) Area
3 Format(1X,'Area=',F10.3)
STOP
END
so the problem when i run the programm is that only the first variable is read "wihtout waiting that i give the second and third variables" and area is directly given as "Area= NaN" some, no error is given while
running, i tried 2 compilers (Intel and Force 2.0.9) with same results. When i modify the format to format(F10.3,F10.3,F10.3) its also not working. What i could do is to read the 3 variables in differents read statements and the program will be like this:
write(*,1)
read(*,2) A
2 format(F10.3)
read(*,3) B
3 format(F10.3)
read(*,4) C
4 format(F10.3)
S=(A+B+C)/2
write(*,5) Area
5 Format(1X,'Area=',F10.3)
PAUSE
STOP
END
In this case its working, so something seems to be wrong in my read and format statement of the 3 variable, i gave exactly the same what is given in the book im using, and there many other programs have read statements in the same manner, so i dont know what im doing wrong or missing. Im very thankful for your support !
Regards.
Ali.
write(*,1)
read(*,2) A, B, C
2 format(3F10.3)
S=(A+B+C)/2
write(*,3) Area
STOP
END
write(*,1)
read(*,2) A
2 format(F10.3)
read(*,3) B
3 format(F10.3)
read(*,4) C
4 format(F10.3)
S=(A+B+C)/2
write(*,5) Area
PAUSE
STOP
END
Regards.
Ali.
RE: beginner in Fortran77
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Re your problem: read as * instead of specifying a format: that way it is free format input. Might be an idea to print the values after you have read them to see what you have read.
first i thank ev. body for support. I found out the problem, when i put format(3F10.3) which is equivalent to put format(F10.3,F10.3,F10.3) then the 3 variables have to be input in the same form as the Format so
A,B,C together and then i have to press enter, when i put Format(F10.3) then i can put the 3 variables after each other as i was trying to do..ok it can be seen evident, but as i said im new in this language..
Concerning xwb´s comment, thank you for recommending newer versions of fortran, i believe many things have been inproved and new things added there, but as i wrote i have other other software(s) based on Fortran77 and old codes as well, that i need to understand them as they are, if i were experienced in Fortran amy be it would be the same for me..
Thanks ev. body,
Ali.
Dan
