NX9 - Delete Face Issue
Hi. When I try to delete a hole face with synchronous delete face, I get an error "delete failed because the remaining faces cannot close the area left...".
I've uploaded a video and the part.
This was not happening in previous NX releases.
Am I doing something wrong?
RE: NX9 - Delete Face Issue
Use your rectangle to select the face(s); there may be a very small face that is hard to see and needs to be deleted so the remaining faces trim properly, and that the rectangle will find
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
Ray S
NX9.0.3.4 MP1
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I would try do reset the dialog of delete face using the round arrow in the delete face dialog title, and try it again.
make sure you have the "right stuff" on your computer
this could even be a graphics card issue
@Jerry1423 Thankfully it was not a graphics card issue.
I do not know what I was doing wrong (especially when I watched how easily John Baker deleted all inner faces), but it was quicker for me to re-install NX and somehow the problem solved. I must had gone something wrong with the first installation or the updates.
Thanks again,
Spada
