Balloon linked to PL without using auto-balloon
Using NX 8.5. I have a large assembly with many views where auto-balloon would not make sense. I have inserted my Parts List, now is there a way to insert single balloons that when I pick the balloon location on the part will put in the corresponding item number from the parts list? I don't usually use integral parts lists so this is a first for me.
Bob Snead
Designer
Northropgrumman.com
RE: Balloon linked to PL without using auto-balloon
Still on NX6, but this is how it has been done for a long time...
Put the balloons in without any text, then update the parts list. As long as the leaders are touching components, they should update.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
It feels like Groundhog Day for some reason...
-Dalai Lama XIV
Thanks, I knew it had to work and was something simple (usually is). I did not see anything explaining this in the help file. Thanks ENG TIPs! and those who responded.
Bob Snead
Designer
Northropgrumman.com
Just make sure your have your points toggled on, on your toolbar; it makes life much easier for you
