Switch to Modeling
Switch to Modeling
I have a part in drafting module and when i want to switch to modeling there is no option to do it.
why modeling module is not available??
what did i do wrong??
Is nx working as expected??
attached it is a movie file where im trying to explain what im saying.(movie.avi)
the thing is i have a small assembly file and i need to make some changes and i can not use modeling. (movie2.avi)
NX 8.5.3.3 MP6
any suggestions to avoid this situation in the future will be appreciated
thanks in advance,
NX 8.5.3.3 MP6
thanks in advance,
______
Alex ,
RE: Switch to Modeling
______
Alex ,
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
The video shows that Gateway is the only option from drafting. Try switching to Gateway and see if you can get to other applications from there. It may be that the drafting menu has been customized (either intentionally or not) to remove the other applications. If you use any MenuScript customizations at your site, perhaps there is an error in one of the .men files.
www.nxjournaling.com
@jerry1423
I been using this licence.
Users of NX13100N: (Total of 634 licenses issued; Total of 252 licenses in use)<---- Checked
@ewh
Start -> All Applications <--- no such option
______
Alex ,
Drafting is the only option from Gateway.
I'm not working under managed mode in this particular case..
but i will investigate about the .men files.
if any of you have another clue I would appreciate all your help
If i cant fix this maybe i need to install all again.
Thanks for all your help..
______
Alex ,
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I used %UGII_BASE_DIR%\UGII\ugraf.exe to launch NX
@cowski
Finally !!.. your suggestion was right.. I do not know why those options were hidden.. i worked on NX yesterday and everything was fine.. but today something happened...
Thank you very much !
______
Alex ,
