converting NX8.5 metric part to inches
I imported an enclusre from a website. It is in metric. I'd like to work in inches and now I'm not able to "make work part" because may layout assy is in inches and the enclosures parts are in metric. How do I get around this? can I convert the enclosure from metric to inches?
RE: converting NX8.5 metric part to inches
thread561-325705: NX convert part units
or search this forum for "convert part" for plenty more threads...
If you only want to convert a single part at a time (as opposed to an assembly or entire folder, which the CLI program will gladly do), you can use this journal:
http://nxjournaling.com/content/convert-part-units
www.nxjournaling.com
It was imported from .stp into an inch files. For some reason, it stayed metric. Once it was an NX file, I did another import of the actual NX file into a new NX inch file, the it was in inches.
