Pipeline Force Profile
If I have a short pipe in pipe pipeline, say 4km long, that is surface laid (i.e. not trenched and buried) and not fully constrained/anchored and so the fully constrained effective axial force is not reached. If I wanted to plot the effective force profile for this, the maximum force is governed by the weight of the pipeline, the friction coefficient and the pipeline route, and then the gradient either side is governed by the friction force, as shown on attached sketch. Is this correct?
Or would a more accurate way of doing it be to calculate the inner pipe force (i.e. spacer friction coeff x Inner pipe Weight x L) and the carrier (carrier friction coeff x Total weight x L) - (spacer friction coeff x Inner pipe Weight x L). Then summing the two of them?
Or am I missing something?
RE: Pipeline Force Profile
you must get smarter than the software you're using.
