Derive CFM from Fan dimension
Hi Guys,
Do you know how to obtain airflow (cfm) using fan dimensions?
What is the formula?
Thanks.
Thanks.
RE: Derive CFM from Fan dimension
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Looking at a Sunon PSD48HDAZBX-A 170x150x51mm fan. Says it's a 3 blade fan - 417.2cfm at 6200RPM. Blade diameter is about 133mm and hub is about 1/3 of that (44mm). So volume is 51*pi/4*(133^2 - 44^2) = 630,671 cubic mm = .0222 cubit ft. So for a single revolution, it would evacuate .0666 cubic feet of air (3*.0222). Running at 6200RPM results in 412 CFM. Not bad for an approximation.
-tg
(hope I didn't make a stupid mistake and just got lucky)
http://xternal.me
