Small, powerful linear actuator with short stroke
I am looking for a linear actuator that has a short stroke (1 to 2 inches) and can put out around 500 lbs. Ideally it would be a discrete 2 position device but not necessary. Non-hydraulic and no squibs. I've looked at screw type actuators but they are mostly unnecessarily long for what I need, and most small solenoid actuators I've seen don't seem to go beyond 50 - 100lbs. Any suggestions?
RE: Small, powerful linear actuator with short stroke
Search Bimba
Ted
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
Otherwise look at ACE, or any of the above manufacturers
Cheers
Greg Locock
Motion Systems does this routinely.
STF
