Applying thermic loads
Hi. I attached a picture of a cross section in a pipe. I need to apply to this pipe, in abaqus, a initial temperature of 20 degrees. After that i need to study the displacements knowing that the inside of the pipe is loaded with a temperature of 300 degrees and the outside with a 200 degrees temperature load.
How do i set this types of loads in Abaqus and what finite element would you recommend me to use in this analysis?
Thank you
Thank you
RE: Applying thermic loads
