How to perform multi-steps analysis in FEMAP-Nastran Linear Static?
Hallo, i am a new user of FEMAP with Nastran, before i used ABAQUS for several years.
I have a question, is it possible in Linear Static module of FEMAP-Nastran, to perform a multi-step analysis?
for example,
Step 1: fixed a node set or apply a small pressure on a surface, to build the contact conditions between parts,
Step 2: release the BC or remove the pressure that set in Step 1, apply the desired BC and real loads
Thanks for any answers from you!
for example,
