PD pump performance
PD pump performance
Hye,
I would like to seek any expert view.
If i want to buy the positive displacement pump, do I need to provide the NPSHa value?
And what is the impact to this pump performance if the NPSHr value is higher than NPSHa?
Thank you.
Thank you.
RE: PD pump performance
If NPSHA < NPSHR, the pump may not work, could suffer damage or at the least performance would suffer.
Different PD pumps have different capabilities for NPSH.
FYI, the medium transfer is fuel with viscosity about 20cSt at 20degC.
With PD pump gear type, why this pump couldn't work if the NPSHa<NPSHr?
Is it because of the cavitation will be occurred at the inlet pump?
Or pressure loss in the pipeline resist the pump to operate?
Tq
