Interstitial Service space - hospitals
I Have this space and I am leaning towards going light hazard for my spacing . There is no mechanical equipment units .other than the typical items you would find above a hospital space . As you can tell I am still a bit hesitant to go light hazard . Has anyone treated these light or ordinary ?
thanks .
Colin
RE: Interstitial Service space - hospitals
What is in the space
How tall is it
NFPA 13 reference why it needs sprinklers?
Should be non-combustible area.
Take it new construction
Is is combustible or non-combustible? Is it concealed or not? NFPA 13 is pretty clear that these spaces are light hazard. If you are protecting it, what is the slope? What is the clearance? If it is <2:12 slope and <36" clear space, you would need to use specially listed sprinklers that will require draft curtains at 1000 sq ft intervals.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
"Follow" us at https://www.facebook.com/pages/MFP-Design-LLC/9221...
sounds like a good area to store stuff in
ok...that is not your typical concealed space above a ceiling. It seems there will be lots of mechanical equipment and potential for storage. I would lean more toward OH1 if potential storage could be limited to 8'. I could easily convince myself to go OH2 in a space like that as well.
We used to do places like this at Intel and it was 0.2/3000 for their criteria. But that was also having a semiconductor fab area below.
I guess I would go no less than OH1. I would look to see what impact OH2 had on my system and if no impact on pipe sizing, then I would go that way just to be conservative.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
