Silos
Silos
I was asked why the uplift on silos is high due to wind load? Any thoughts?
Also is there any deflection limitation for top of silos? Any top displacement restriction?
Thank you
Thank you
RE: Silos
1. Makes the foundation heavier, thereby lowering the center of mass for the silo / foundation unit.
2. Makes the foundation more stable by increasing the foundation's lever arm to resist overturning.
3. Increases the contact area with the soil, giving more space to install additional piling, drilled piers, etc. to resist uplift.
www.SlideRuleEra.net
www.VacuumTubeEra.net
RE: Silos
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
