After I use "Delete Face", without heal, how do I add a surface that I removed?
In this attachment you'll see 2 flanges. I have to remove them to be able to fold out the part. I removed one flange using "Delete Face". But somehow I have to use the Heal option because it becomes like a shell when I just use delete face. I've tried using "Patch" and "Stitch" but that didn't do any good. I tried using "Delete Face" at the small transitional radius before the flange and then removing the rest of the flange but that didn't work either. I'm out of ideas.
Anyone got anything?
RE: After I use "Delete Face", without heal, how do I add a surface that I removed?
STF
