Error in NxOpen API when trying to use "divide face"
Hi
I use NxOpen api both within journaling and as stand-alone application(without UI). I also use both java and C# as programming languages in these two modes. I use different classes and create different feature builders in both environments pretty the same with no problem. But when I try to create a Divide Face builder it only works within journaling environment. The same command results in an internal error when I write stand alone programs. Following is the code in Java:
DividefaceBuilder dividefaceBuilder1 = myNxPart.features().createDividefaceBuilder(null);
and the exception:
Exception in thread "main" nxopen.NXException: Internal error: memory access violation
at nxopen.features.FeatureCollection_impl.createDividefaceBuilder(Native Method)...
Same thing happens in C# as well. Seems to be a bug within the API layers. Any idea?
RE: Error in NxOpen API when trying to use "divide face"
May be a bug...
I'd suggest bringing it to the attention of GTAC.
www.nxjournaling.com
