cracks in the slab
cracks in the slab
cracks in the slab
Good morning,
please somebody tell me the best procedures for a structural engineer to do after he finds there are cracks underneath the slab?
RE: cracks in the slab
Have you established the cause of the cracks?
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
Get out from standing below said cracks until source is known.
Following publication may help you in this regard:
ACI 224.1R-07 Causes, Evaluation, and Repair of Cracks in Concrete Structures
If possible, about a picture of the cracks to see how they are aligned to the slab
Figure out the cause of the cracks. Decide if they are of concern. Determine what repair if any is needed.
I checked the design again and it was OK. I went to the site and the depth is OK. The cracks are going diagonally as yield lines would go. How do I check that the compressive strength and rebars in the slab are ok?
what is the cracking moment of the slab and what is the actual load when cracks occurred. I would start with the common issues such as cover, depth of slab ect.
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
Just knowing that there are cracks doesn't tell us much, as most concrete structures, particularly the slabs, have some cracking. A description of the structure would help, along with identification of where the cracks are occurring.
