Derating factor-Y
Derating factor-Y
Hello all!
Per 31.3/31.1, there is a relation between Temperature and De-rating factor (value of coefficient) in the Table provided.
Is there any relation with Pipe thickness and practical aspect in piping.
Thanks for your valuable comments....
RE: Derating factor-Y
What practical aspect are you thinking of - this is a vague question....
For lower temperatures, the result is a smaller required thickness as for larger temperatures, the Y-value increases.
Be aware of the limitations of the Y-factor for thicker components ( T>=D/6)
