Associative Text/Attributes
Version NX 8.5
I'm working on a detail drawing for a weldment. The weldement has 12 pieces. Sheet 1 is the weldment assembly named XXXXXX and sheet 2 is the detail drawings for all of the individual pieces which are named XXXXXX-01 through XXXXXX-12. Is there a way to create associative text that will automatically populate the correct drawing number for each of my 12 individual pieces? i.e. I place the text under the view of part number XXXXXX-01 (this text is somehow linked to the view of part number XXXXXX-01) and with in that text the part number XXXXXX-01 would automatically populate.
RE: Associative Text/Attributes
I think there is a way to do this with some programming, so maybe one of thos experts can give you advice
I know John Baker is on the road, so maybe when he gets back he can help you
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Richard
This sounds more like what I'm looking for however this is vague could you please be more specific.
Trent
When you are creating (or editing) text in the Annotation Editor (Insert --> Annotation --> Note), In the Text Input pane, there is a Symbols section. If you expand that option, you will find an option called Category. This option has a pull down menu with several option available. Here is what you do:
1. Set the Category option to Relationships.
2. Select the icon next to Insert Object Attribute.
3. A dialog will appear asking you to Select Object. Pick your component in any drawing view.
4. A dialog will appear with a list of Attributes. Select the part number attribute in that component and select OK.
5. The text string will look something like <WRef1*0@YOURATTRIBUTE>
You can repeat these steps for each sheet/view you want to place the text under.
Hope this helps,
Richard
