Space before Percent Sign
I continue to lurk, mostly, in an editor's facebook group. They bring up technical stuff from time to time.
Do you place a space between a number and a percent sign, or units in general? Do 37.6% of us make up statistics on the spot, or is it 48.2 % of us that do it?
JHG
RE: Space before Percent Sign
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I think I am afraid to loose the % so I stick together with the number and then I sleep better.
"If you want to acquire a knowledge or skill, read a book and practice the skill".
1) % may be used in headlines only. In text, it should be spelled out 'percent.'
2) When % is used, no space after the number as the others have said.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
http://www.spe.org/authors/docs/styleguide.pdf
Most arguments like this are either based on preference or clarity. This one seems to be preference, no loss in clarity either way.
- Steve
On my original post, I applied a non-breaking space between the number and the percent sign. The HTML code for non-breaking space is &nsbp;. You place this between square brackets and the Tecumseh editor converts it to HTML.
If you cannot apply non-breaking spaces, then your concern is correct, and fairly nasty.
JHG
It happened when I was filling out an excel spreadsheet and I was instinctively sticking like hell the number and percent sign.
I even tried to put a space but I did not feel good about it...
Mike McCann, PE, SE (WA)
