revisions on each sheet of multiple sheet drawing
hello - this may have been discussed here before so please accepy my appology if it has - our company has NO STANDARDS - only standards that some people who think they know everything dictate to all the rest of us - i was always taught that if a multiple sheet drawing has revisions that the revision should show up on each sheet as far as the rev number goes but only the description of the revision being made should show up om just the sheet it applies to - all other sheets should say see sheet no.x for revision - what is the correct way to do this or the standards way - any help would be appreciated - thank you
RE: revisions on each sheet of multiple sheet drawing
In the mechanical design world, I have not seen this practice in probably 25 years.
Chris, CSWA
SolidWorks 14
SolidWorks Legion
Whatever you do, try to avoid having separate revision levels for individual sheets as this can cause configuration nightmares, and most modern CAD systems can't support it without requiring a separate file for each sheet.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
--Scott
www.wertel.pro
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Ben Loosli
