ART2 kit applied to AR9344
I'm not a developer of Embedded system. My project is use AR9344 to setup a system in long haul clock convey purpose. I already have ART2 kit in hand, I want to make sure whether I could use USB device mode to config a Board based on AR9344(not fully comply to the DB120). Because there is no Ethernet port or PCIE port available.
I use a NAND flash to boot the chip. For the customized usage, it is 5GHz single direction communication.
RE: ART2 kit applied to AR9344
I suggest that you direct this question to Atheros, the manufacturer of the AR9344, first.
Z
For I don't have sell source account, the qca department did not respond
