heat transfer
heat transfer
heat transfer
hi to all pls i need to calculate heat duty for air cooler inlet condition
fluid name natural gas
total entering fluid lb\h 93025
in out
in out *specific heat (ligid\vapor) ( \ .51) (.55\)
*temperture f 252 125 btu\lb-f
*liqid lb\h 6500 * latent heat btu\lb 120
*vapor lb\h 91223 84723
*steam lb\h 1802 102
*water lb\h 1700
i know total heat duty which heat exchange is 8526000 btu\hr
i want to calculate this valve from given data pls help
RE: heat transfer
If there are no responses, the reason is that the OP does not make sense, so you should get an engineer to figure out what you are trying to do.
