Linear union of points
Hi All,
I have a quick question regarding the connection of points through splines. What I want to do is to import all the points from an excel file and then connect them using STRAIGHT lines. I have used a macro that comes with the CATIA package (GSD_PointSplineLoftFromExcel.xls) to see what it does and found out that it can connect the points but the result is an SMOOTH spline. I would like to modify the code to obtain straight lines instead. I presume that this will be a matter of changing a couple of lines of code but I can't get my head around about how to do it (I am new in both CATIA and Visual Basic :)).
I have attached the xls file with the coordinates already in place and some pictures.
If you could help me on this that would be great.
Many thanks.
'// COPYRIGHT DASSAULT SYSTEMES 2001
'// Generative Shape Design
'// point, splines, loft generation tool
Const Cst_iSTARTCurve As Integer = 1
Const Cst_iENDCurve As Integer = 11
Const Cst_iSTARTLoft As Integer = 2
Const Cst_iENDLoft As Integer = 22
Const Cst_iSTARTCoord As Integer = 3
Const Cst_iENDCoord As Integer = 33
Const Cst_iERRORCool As Integer = 99
Const Cst_iEND As Integer = 9999
Const Cst_strSTARTCurve As String = "StartCurve"
Const Cst_strENDCurve As String = "EndCurve"
Const Cst_strSTARTLoft As String = "StartLoft"
Const Cst_strENDLoft As String = "EndLoft"
Const Cst_strSTARTCoord As String = "StartCoord"
Const Cst_strENDCoord As String = "EndCoord"
Const Cst_strEND As String = "End"
'To define the kind of elements to create (1: create only points
'2: creates points and splines
'3: Creates points, splines and loft
Function GetTypeFile() As Integer
Dim strInput As String, strMsg As String
choice = 0
While (choice < 1 Or choice > 3)
strMsg = "Type in the kind of entities to create (1 for points, 2 for points and splines, 3 for points, splines and loft):"
strInput = InputBox(Prompt:=strMsg, _
Title:="User Info", XPos:=2000, YPos:=2000)
'Validation of the choice
choice = CInt(strInput)
If (choice < 1 Or choice > 3) Then
MsgBox "Invalid value: must be 1, 2 or 3"
End If
Wend
GetTypeFile = choice
End Function
'Get the active cell
Function GetCell(iindex As Integer, column As Integer) As String
Dim Chain As String
Sheets("Feuil1").Select
If (column = 1) Then
Chain = "A" + CStr(iindex)
ElseIf (column = 2) Then
Chain = "B" + CStr(iindex)
ElseIf (column = 3) Then
Chain = "C" + CStr(iindex)
End If
Range(Chain).Select
GetCell = ActiveCell.Value
End Function
Function GetCellA(iRang As Integer) As String
GetCellA = GetCell(iRang, 1)
End Function
Function GetCellB(iRang As Integer) As String
GetCellB = GetCell(iRang, 2)
End Function
Function GetCellC(iRang As Integer) As String
GetCellC = GetCell(iRang, 3)
End Function
'Syntax of the parameter file
'StartCurve -> to start the list of points defining the spline
' double , double , double
' double , double , double -> as many points as necessary to define the spline
'EndCurve -> to end the list of points defining the spline
'Example:
'StartCurve
' -10.89, 10 , 46.78
'1.56, 4, 6
'EndCurve -> spline composed of 2 points
Sub ChainAnalysis(ByRef iRang As Integer, ByRef X As Double, ByRef Y As Double, ByRef Z As Double, ByRef iValid As Integer)
Dim Chain As String
Dim Chain2 As String
Dim Chain3 As String
Chain = GetCellA(iRang)
Select Case Chain
Case Cst_strSTARTCurve
iValid = Cst_iSTARTCurve
Case Cst_strENDCurve
iValid = Cst_iENDCurve
Case Cst_strSTARTLoft
iValid = Cst_iSTARTLoft
Case Cst_strENDLoft
iValid = Cst_iENDLoft
Case Cst_strSTARTCoord
iValid = Cst_iSTARTCoord
Case Cst_strENDCoord
iValid = Cst_iENDCoord
Case Cst_strEND
iValid = Cst_iEND
Case Else
iValid = 0
End Select
If (iValid <> 0) Then
Exit Sub
End If
'Conversion string -> double
Chain2 = GetCellB(iRang)
Chain3 = GetCellC(iRang)
If ((Len(Chain) > 0) And (Len(Chain2) > 0) And (Len(Chain3) > 0)) Then
X = CDbl(Chain)
Y = CDbl(Chain2)
Z = CDbl(Chain3)
Else
iValid = Cst_iERRORCool
X = 0#
Y = 0#
Z = 0#
End If
End Sub
' Get CATIA Application
'Remark:
' When KO, update CATIA registers with:
' CNEXT /unregserver
' CNEXT /regserver
Function GetCATIA() As Object
Set CATIA = GetObject(, "CATIA.Application")
If CATIA Is Nothing Then
Set CATIA = CreateObject("CATIA.Application")
CATIA.Visible = True
End If
Set GetCATIA = CATIA
End Function
' Get CATIADocument
Function GetCATIAPartDocument() As Object
Set CATIA = GetCATIA
Dim MyPartDocument As Object
Set MyPartDocument = CATIA.ActiveDocument
Set GetCATIAPartDocument = MyPartDocument
End Function
' Creates all usable points from the parameter file
Sub CreationPoint()
'Get CATIA
Dim PtDoc As Object
Set PtDoc = GetCATIAPartDocument
' Get the HybridBody
Dim myHBody As Object
Set myHBody = PtDoc.Part.HybridBodies.Item("GeometryFromExcel")
Dim iLigne As Integer
Dim iValid As Integer
Dim X As Double
Dim Y As Double
Dim Z As Double
Dim Point As Object
iLigne = 1
'Analyze file
While iValid <> Cst_iEND
'Read a line
ChainAnalysis iLigne, X, Y, Z, iValid
iLigne = iLigne + 1
'Not on a startcurve or endcurve -> valid point
If (iValid = 0) Then
Set Point = PtDoc.Part.HybridShapeFactory.AddNewPointCoord(X, Y, Z)
myHBody.AppendHybridShape Point
End If
Wend
'Model update
PtDoc.Part.Update
End Sub
' Creates all usable points and splines from the parameter file
'Limitations:
' ============================> NO MORE THAN 500 POINTS PER SPLINE
Sub CreationSpline()
'Limitation : points per spline
Const NBMaxPtParSpline As Integer = 500
'Get CATIA
Dim PtDoc As Object
'Get HybridBody
Dim iRang As Integer
Dim X1 As Double
Dim Y1 As Double
Dim Z1 As Double
Dim index As Integer
Dim PassingPtArray(1 To NBMaxPtParSpline) As Object
Dim spline As Object
Dim ReferenceOnPoint As Object
Dim SplineCtrPt As Object
iValid = 0
iRang = 1
'Analyze file
'reinitialization of point array of the spline
index = 0
'Remove records before StartCurve
While ((iValid <> Cst_iSTARTCurve) And (iValid <> Cst_iEND))
ChainAnalysis iRang, X1, Y1, Z1, iValid
iRang = iRang + 1
Wend
If (iValid <> Cst_iEND) Then
'Read until endcurve -> Spline completed
While ((iValid <> Cst_iENDCurve) And (iValid <> Cst_iEND))
iRang = iRang + 1
'valid point
index = index + 1
If (index > NBMaxPtParSpline) Then
MsgBox "Too many points for a spline. Point deleted"
Else
Set PassingPtArray(index) = PtDoc.Part.HybridShapeFactory.AddNewPointCoord(X1, Y1, Z1)
myHBody.AppendHybridShape PassingPtArray(index)
End If
End If
Wend
'Start building spline
'Are there enough points ?
If (index < 2) Then
MsgBox "Not enough points for a spline. Spline deleted"
Else
Set spline = PtDoc.Part.HybridShapeFactory.AddNewSpline
spline.SetSplineType 0
spline.SetClosing 0
'Creates and adds points to the spline
For i = 1 To index
Set ReferenceOnPoint = PtDoc.Part.CreateReferenceFromObject(PassingPtArray(i))
' ---- Version Before V5R12
' Set SplineCtrPt = PtDoc.Part.HybridShapeFactory.AddNewControlPoint(ReferenceOnPoint)
' spline.AddControlPoint SplineCtrPt
' ---- Since V5R12
spline.AddPointWithConstraintExplicit ReferenceOnPoint, Nothing, -1, 1, Nothing, 0
Next i
myHBody.AppendHybridShape spline
End If
End If
Wend
PtDoc.Part.Update
End Sub
Sub LookForNextSpline(ByRef iRang As Integer, ByRef spline As Object, ByRef iValid As Integer, ByRef iOKSpline)
'Limitation number off point per spline
'Get CATIA
Dim PtDoc As Object
'Get HybridBody
Dim X1 As Double
Dim Y1 As Double
Dim Z1 As Double
iValid = 0
iOKSpline = 0
index = 0
iRang = iRang + 1
Wend
iRang = iRang + 1
'valid point
index = index + 1
Else
End If
End If
Wend
If (index < 2) Then
Else
For i = 1 To index
' ---- Since V5R12
spline.AddPointWithConstraintExplicit ReferenceOnPoint, Nothing, -1, 1#, Nothing, 0#
Next i
spline.SetClosing 0
iOKSpline = 1
End If
End If
End Sub
' Creates all usable points, splines and loft from the parameter file
'Limitations:
' ============================> NO MORE THAN 50 SPLINEs PER LOFT
Sub CreationLoft()
'Limitations
Const NBMaxSplineParLoft As Integer = 50
'Get CATIA
Dim PtDoc As Object
'Get HybridBody
Dim X1 As Double
Dim Y1 As Double
Dim Z1 As Double
Dim indexSpline As Integer
Dim SplineArray(1 To NBMaxSplineParLoft) As Object
Dim Ref As Object
Dim CtrPt As Object
indexSpline = 1
iValid = 0
iRang = 1
'Analyze file
index = 0
'Remove records before StartLoft
While (iValid <> Cst_iSTARTLoft)
iRang = iRang + 1
Wend
'Search curve defining the loft
While (iValid <> Cst_iEND)
If (indexSpline > NBMaxSplineParLoft) Then
MsgBox "Too many splines for the loft"
iValid = Cst_iEND
Else
LookForNextSpline iRang, SplineArray(indexSpline), iValid, iOKSpline
If (iOKSpline = 1) Then
indexSpline = indexSpline + 1
End If
If (iValid = Cst_iEND) Then
indexSpline = indexSpline - 1
End If
End If
Wend
Wend
' Create the loft
If (indexSpline > 1) Then
Dim Loft As Object
Set Loft = PtDoc.Part.HybridShapeFactory.AddNewLoft
Dim LocalRefSpline As Object
Dim SectionLoft As Object
For i = 1 To indexSpline
Set LocalRefSpline = PtDoc.Part.CreateReferenceFromGeometry(SplineArray(i))
' Set SectionLoft = PtDoc.Part.HybridShapeFactory.AddNewLoftSection(LocalRefSpline, 1)
' Loft.AddSection SectionLoft
' ---- Since V5R12
Loft.AddSectionToLoft LocalRefSpline, 1, Nothing
Next i
myHBody.AppendHybridShape Loft
End If
' Model update
PtDoc.Part.Update
End Sub
'Main program
Sub Main()
'Get the type of operations to do:
' Points --> 1
' Splines + Points --> 2
' Loft + Splines + Points --> 3
Dim TypeFile As Integer
TypeFile = GetTypeFile
' V5R12 - Create dedicate opneBody for created geometry
'Get CATIA
Dim PtDoc As Object
' Create Open body
Set myHBody = PtDoc.Part.HybridBodies.Add()
Set referencebody = PtDoc.Part.CreateReferenceFromObject(myHBody)
PtDoc.Part.HybridShapeFactory.ChangeFeatureName referencebody, "GeometryFromExcel"
If TypeFile = 1 Then
CreationPoint
ElseIf TypeFile = 2 Then
CreationSpline
ElseIf TypeFile = 3 Then
CreationLoft
End If
End Sub
Many thanks.
choice = 0
End If
Wend
End Function
Dim Chain As String
End If
Range(Chain).Select
End Function
End Function
End Function
End Function
'Example:
'StartCurve
'1.56, 4, 6
Dim Chain As String
Select Case Chain
Case Cst_strENDLoft
Case Cst_strEND
iValid = Cst_iEND
Case Else
iValid = 0
End Select
Exit Sub
End If
X = CDbl(Chain)
Y = CDbl(Chain2)
Z = CDbl(Chain3)
Else
X = 0#
Y = 0#
Z = 0#
End If
End Sub
'Remark:
' CNEXT /regserver
End If
End Function
' Get CATIADocument
End Function
Sub CreationPoint()
'Get CATIA
Dim PtDoc As Object
Dim X As Double
Dim Y As Double
Dim Z As Double
Dim Point As Object
iLigne = 1
'Analyze file
'Read a line
iLigne = iLigne + 1
End If
Wend
'Model update
PtDoc.Part.Update
End Sub
'Limitations:
'Get CATIA
Dim PtDoc As Object
'Get HybridBody
Dim X1 As Double
Dim Y1 As Double
Dim Z1 As Double
iValid = 0
iRang = 1
'Analyze file
index = 0
iRang = iRang + 1
Wend
iRang = iRang + 1
'valid point
index = index + 1
Else
End If
End If
Wend
If (index < 2) Then
Else
spline.SetClosing 0
For i = 1 To index
' ---- Since V5R12
Next i
End If
End If
Wend
PtDoc.Part.Update
End Sub
'Get CATIA
Dim PtDoc As Object
'Get HybridBody
Dim X1 As Double
Dim Y1 As Double
Dim Z1 As Double
iValid = 0
iOKSpline = 0
index = 0
iRang = iRang + 1
Wend
iRang = iRang + 1
'valid point
index = index + 1
Else
End If
End If
Wend
If (index < 2) Then
Else
For i = 1 To index
' ---- Since V5R12
Next i
spline.SetClosing 0
iOKSpline = 1
End If
End If
End Sub
'Limitations:
Sub CreationLoft()
'Limitations
'Get CATIA
Dim PtDoc As Object
'Get HybridBody
Dim X1 As Double
Dim Y1 As Double
Dim Z1 As Double
Dim Ref As Object
Dim CtrPt As Object
indexSpline = 1
iValid = 0
iRang = 1
'Analyze file
index = 0
iRang = iRang + 1
Wend
iValid = Cst_iEND
Else
End If
End If
End If
Wend
Wend
' Create the loft
Dim Loft As Object
' ---- Since V5R12
Next i
End If
' Model update
PtDoc.Part.Update
End Sub
'Main program
Sub Main()
' Points --> 1
'Get CATIA
Dim PtDoc As Object
' Create Open body
CreationPoint
CreationSpline
CreationLoft
End If
End Sub
RE: Linear union of points
CODE --> VBA
Sub New_Polyline() Path = "C:\Alex\Book.xls" Dim documents1 As Documents Set documents1 = CATIA.Documents Dim partDocument1 As Document Set partDocument1 = documents1.Add("Part") Dim part1 As Part Set part1 = partDocument1.Part Dim bodies1 As Bodies Set bodies1 = part1.Bodies Dim body1 As Body Set body1 = bodies1.Item("PartBody") Set hybridBodies1 = part1.HybridBodies Set Hybridbody1 = hybridBodies1.Add() Set hybridShapes1 = Hybridbody1.HybridShapes part1.InWorkObject = hybridShapes1 Dim Excel As Object Set Excel = CreateObject("Excel.Application") Set workbook = Excel.Workbooks.Open(Path) Set HSF = part1.HybridShapeFactory Set hybridShapePolyline1 = HSF.AddNewPolyline() LastRow = Excel.Range("A65536").End(xlUp).Row For I = 1 To LastRow x = Excel.Cells(I, 1).Value y = Excel.Cells(I, 2).Value z = Excel.Cells(I, 3).Value Set Point = HSF.AddNewPointCoord(x, y, z) Set HybridShapePointCoord = Point Set reference1 = part1.CreateReferenceFromObject(HybridShapePointCoord) hybridShapePolyline1.InsertElement reference1, I Next I Set Excel = Nothing hybridShapePolyline1.Closure = False Hybridbody1.AppendHybridShape hybridShapePolyline1 part1.InWorkObject = hybridShapePolyline1 part1.Update End Sub______
Alex ,
Seems like a very helpful code to start with. However I am getting an error when I try to run it. See below:
Execute the script ‘PolylineToCatia.catvbs”.
The scripting engine for CATScript has reported the following error:
Source: Microsoft VBScript compilation error
Description: Expected end of statement
Statement Next I
Line: 51
Column: 5
See the language reference guide or the VS Automation APIs
Documentation.
Would you like to edit the macro source code now?
Any idea why this is happening?
Thank you.
CODE --> catvbs
Language="VBSCRIPT" Sub CATMain() Path = "C:\Alex\Book.xls" Dim documents1 'As Documents Set documents1 = CATIA.Documents Dim partDocument1 'As Document Set partDocument1 = documents1.Add("Part") Dim part1 'As Part Set part1 = partDocument1.Part Dim bodies1 'As Bodies Set bodies1 = part1.Bodies Dim body1 'As Body Set body1 = bodies1.Item("PartBody") Set hybridBodies1 = part1.HybridBodies Set Hybridbody1 = hybridBodies1.Add() Set hybridShapes1 = Hybridbody1.HybridShapes part1.InWorkObject = hybridShapes1 Dim Excel 'As Object Set Excel = CreateObject("Excel.Application") Set workbook = Excel.Workbooks.Open(Path) Set HSF = part1.HybridShapeFactory Set hybridShapePolyline1 = HSF.AddNewPolyline() Dim LastRow 'As Integer LastRow = Excel.Range("A65536").End(-4162).Row For I = 1 To LastRow x = Excel.Cells(I, 1).Value y = Excel.Cells(I, 2).Value z = Excel.Cells(I, 3).Value Set Point = HSF.AddNewPointCoord(x, y, z) Set HybridShapePointCoord = Point Set reference1 = part1.CreateReferenceFromObject(HybridShapePointCoord) hybridShapePolyline1.InsertElement reference1, I Next 'I Set Excel = Nothing hybridShapePolyline1.Closure = False Hybridbody1.AppendHybridShape hybridShapePolyline1 part1.InWorkObject = hybridShapePolyline1 part1.Update End Sub______
Alex ,
