Thermal stresses - slab on ground
Hi, I am looking at an external concrete slab on ground.
Can someone tell me what would be the likely thermal gradient through the slab depth?
Also is the thermal gradient generally a constant value or does it vary significantly with the slabs thickness?
Thanks in advance.
Thanks in advance.
RE: Thermal stresses - slab on ground
Maine EIT, Civil/Structural.
I want to be sure what you think it is is what I think it is. 8<)
