How close HV insulators can be places?
on the same phase, is there a limit for the distance between any two successive insulators? (regardless of maintenance requirement)
for SA, I have seen a half phase - to - earth clearance requirement and full phase to earth on the grounded part. Is this applicable to other equipment not around SA?
Any clue?
Any clue?
RE: How close HV insulators can be places?
Two pin or post type insulators supporting an overhead distribution line conductor on double crossarms is common. This would put the insulators spaced at the pole diameter plus the crossarm width, about 25 cm.
is 25 cm dependent on voltage? similar to Surge arrestor case?
