Soil spring stiffness
Hello All
Could someone please explain why do we provide soil spring for structure for analysis, or the main purpose of it
Bye
Bye
RE: Soil spring stiffness
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
Thanks but how we can verify it by using in staadpro or any other FEM software,kindly explain in brief
I have this details with me
bearing capacity = 200KN/m2
allowable settlement = 10mm
FOS = 2
Bye
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
The allowable bearing pressure provided by a geotechnical engineer is generally based on limiting settlement to an acceptable value. So, bearing pressure is related to settlement.
In your case, the allowable bearing pressure (200 kN/m2) is directly correlated to a settlement of 10 mm.
Thus, your soil spring constant would be 20,000 kN/m3.
DaveAtkins
KootK: Yeah I think it would. The 400kPa is the "real" value, although I've always varied springs from 50% to 200% of the given value anyway to be sure the structure isn't too sensitive
