Wave link to reusable component
What is the best practice when creating wave links to standard parts from the reuse library? Apparently the parent part file of a wave link needs to be modified which isn't possible because it is a standard part.
Right now I'm using 'make unique' but it doesn't feel like the right solution to the problem.
Assume the construction of a bearing cap based on a bearing from the standard parts library that I added to the assembly. I would like to wave link some faces of the bearing into the cap part to base the construction upon, but I can't because creating the links will require saving of the 'volatile' bearing part from the standard parts catalogue.
RE: Wave link to reusable component
That being said, doing a 'Make Unique' operation is probably as elegant a solution as there is, just keep in mind that the newly created Component part file will have NO sense of it being a Family Table member. That is, if you were to make a change yo the Family template part with the intention that this is a global change, when you update the Family members, this 'orphaned' part will be unaware of this change and will not update.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
From a users point of view I don't. I just want to link geometry from the instance into another part.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Cleaned up the windows temp folder (contained temporary folders regarding the reuse library)and it turn out that now, when loading an assembly that contains standard parts, these parts are not loaded and nx complains. Can't figure out yet how things are supposed to work. Setting the assembly load preferences manually to search the folder where the standard parts are installed now picks the correct parts but the instances are created in inches instead of metric (all scaled up by 25.4). A Huge mess...
