NXOPEN C#, How to handle select event in listbox(dialog)
I wanna do something when select item(s) in listbox.
For example,
There is a list box as below.
[Listbox]
| 1. A1234-0 |
| 2. A1515-0 |
| 3. B1234-0 |
| 4. B1515-0 |
[OK] [APPLY] [CANCEL]
Select "1. A1234-0" in listbox -> Select component "A1234-0".
I visited GTAC Solution center but couldn't find any sample code.
I would be appreciated if you could give me sample code.
Thanks in advance for your advice.
Windows7 Pro. 64bit
NX 7.5
RE: NXOPEN C#, How to handle select event in listbox(dialog)
What are you using as your UI; the NX blockstyler, or a windows form?
www.nxjournaling.com
Cowski, Thank you for your reply.
Actually I already solved by myself.
I'm using NX blockstyler and added some code in update_cb function.
It works well.
