looking for a special valve
I'm new here and I wanted to ask your help with something ...
I am looking for a valve that allows the flow of liquid but prevent air escaping out form let's say a sealed container ...
Is there such a thing?
RE: looking for a special valve
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. —Galileo Galilei, Italian Physicist
You're not actually looking for a valve, what you need to look for is level control, the type of valve is irrelevant.
If you turn a ball cock from your toilet upside down it would do something like that
YES!
Any 'steamtrap' based on a float construction is especially constructed to do this. To get a proper answer you have to contact specialists (Spirax sarco, Gestra, Armstrong,.. a lot of others) giving details of your fluids and amounts for dimensioning and proper materials, including sealings.
Any movements/transport of the container to influence solution? Any requirements of allowable leaking amounts of air?
Note: piping layot and necessary additional components (checkvalves, isolating valves, filters) essential for a good solution.
Our floating ball check valves were manufactured by Vogt with the following description:
1” Vogt - Model #5-4853 – special steel flanged valve – 300# ANSI R.F. – with special 1-1/4” stainless steel hollow floating ball.
Johnny Pellin
