Time History Analysis Of 2D Frame Using MATLAB (El Centro)
Consider a 2D frame like below which excited by el Centro earthquake:
I'm Using Direct Time Integration To obtain response of structure. I verified my program with SAP200 when a Harmonic load applied in node2 and results are the same. but in this case, i.e. base excitation, i have a problem. Consistent Mass Matrix used here and following relation used in order to obtain nodal forces due to base excitation:
{fg}=-[M]*{Ag}*Ug
and We know that:
[M]{A}+[C]{V}+[K]{D}={fg}
in which [M]=Consistent Matrix (6x6 in this case), {Ag} = Influence Vector (6x1) which is zero except for horizontal degrees of freedom, i.e 4 & 7 that equals to 1. in other words {Ag}=[1,0,0,1,0,0].also Ug is a scalar number that equals to earthquake record data at time t. I wonder if this is Right or Wrong? i know somethings wrong with this because i can't get correct results. I really appreciate if you help me.
thanx...
{fg}=-[M]*{Ag}*Ug
and We know that:
thanx...
RE: Time History Analysis Of 2D Frame Using MATLAB (El Centro)
Cheers
Greg Locock
Cheers
Greg Locock
Cheers
Greg Locock
Cheers
Greg Locock
One quick way to solve this (very crude) is to attach a large mass to your nodes 1 and 2, and then drive that mass with a force equal to "Large mass" * "ground acceleration".
It might take some finding, but it must be in Opensees somewhere.
http://opensees.berkeley.edu/
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
