Question regarding compaction of backfill on native soil
I have received an RFV requesting that we change the backfill material that we've specified underneath footings from granular fill to stockpiled native material (pit run sand).
The contractor has asked for the change because they are concerned that cross contamination between the native material an the granular backfill we wish to add on top of it will lead to compaction issues. I haven't come across this being an issue before.
I'm concerned that the native backfill will be susceptible to frost action. Do you think they're looking to use the native material as a cost saving move?
Thanks for your help in advance.
RE: Question regarding compaction of backfill on native soil
Have them prove that the sand is not frost susceptible. or make them use clean sand.
As to degree of frost susecptibility, I have yet to see plan approving agencies allow lesser depth of foundation just to recognze that the soil is not frost susceptible. Usually a building code sets that depth regardless of soil type. An exceptiin is placing founationon bedrick. Better check that out before establising footing grades.
