Changing colours....
So, I have to change the colour of many components in a sub-assembly. I have to do this because...well... its a long story and involves a gnashing of teeth...
So. I have an assembly (A) which has several sub-assemblies (B1 to B5), which each have several sub-assemblies...and so on.
How do I change the colour of a sub-assembly at the component level. That is; if I choose sub-assy B1: ALL the components change to a certain colour down to the component level; so that when I open each individual component they are also that colour?
I know that changing the assy colour changes the colour in that assy, but not at the component level. Is there a way to do this? or does someone have a journal file for this?
Thanks!
Mauricio Haliska
Eng. Mgr.
www.Metrican.com
RE: Changing colours....
and to force the selection to faces and solids
you need to go into the Type fiter
and make sure only Face and Solid
are highlighted
