Transient Thermal Analysis in FEMAP
Hello all
I need some help in thermal analysis in FEMAP/NX-Nastran. I have 17 layers stacked on each other. Initial temperature at the bottom and top of the layer is set at 250F. I would like to know the temperature of each layer as time goes on. How do I do that?
Total time duration is 2hrs (7200 secs) and I would like to know the temperature of each layer at every 120 secs
I would appreciate if someone could help me on this.
Modeldamper
Modeldamper
RE: Transient Thermal Analysis in FEMAP
I am struggling as well in this area. If anyone with experience could help out, that would be great.
Btw modeldamper,
how did you set your initial temperature of both surfaces? I cannot figure the appropriate approach.
1. Under materials section, set reference temperature?
2. Under Analysis > Manage > Masters Request and Condition > Boundary Conditions > (tick) initial condition? if so, how do you set this up under loading section?
Another question is, in order to set an adiabatic boundary condition,
do I just set heat flux = 0 at selected surfaces?
Please advice.
Cheers,
Chin
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Sorry, I couldn't get back to you. Here is the .dat file. Top layer and the bottom layer are set at 250F and their nodes are 1,2,3,4,205,206,207,208. Rest of the nodes (middle layers) are set at 70F. Specific heat for material varies and I have assumed 80000 here. Hope this helps.
INIT MASTER(S)
NASTRAN SYSTEM(442)=-1,SYSTEM(319)=1
ID Femap,Femap
SOL NLTCSH
TIME 10000
CEND
ANALYSIS = HEAT
TITLE = NX Nastran Trans Heat Analysis Set
ECHO = NONE
THERMAL(SORT1,PLOT) = ALL
SPCFORCE(PLOT) = ALL
FLUX(PLOT) = ALL
IC = 2
SPC = 1
TSTEPNL = 1
BEGIN BULK
$ Written by : Femap with NX Nastran
$ Version : 11.1.2
$ Translator : NX Nastran
$ From Model :
$ Date : Fri Oct 10 10:38:03 2014
PARAM,PRGPST,NO
TSTEPNL 1 100 12. 10 10 U+
+ .001 +
+ 0 NO+
PARAM,POST,-1
PARAM,OGEOM,NO
PARAM,AUTOSPC,NO
PARAM,K6ROT,100.
PARAM,GRDPNT,0
CORD2C 1 0 0. 0. 0. 0. 0. 1.+FEMAPC1
+FEMAPC1 1. 0. 1.
CORD2S 2 0 0. 0. 0. 0. 0. 1.+FEMAPC2
+FEMAPC2 1. 0. 1.
$ Femap with NX Nastran Property 2 :
PSOLID 2 1 0
$ Femap with NX Nastran Property 3 :
PSOLID 3 2 0
$ Femap with NX Nastran Property 4 :
PSOLID 4 1 0
$ Femap with NX Nastran Property 5 :
PSOLID 5 1 0
$ Femap with NX Nastran Material 1 :
MAT4 1 6.741 800000. 1. 1.
$ Femap with NX Nastran Material 2 :
MAT4 2 6.741 800000. 1. 1.
SPC 1 1 1 250.
SPC 1 2 1 250.
SPC 1 3 1 250.
SPC 1 4 1 250.
SPC 1 205 1 250.
SPC 1 206 1 250.
SPC 1 207 1 250.
SPC 1 208 1 250.
TEMP 2 5 70.
TEMP 2 6 70.
TEMP 2 7 70.
TEMP 2 8 70.
TEMP 2 9 70.
TEMP 2 10 70.
TEMP 2 11 70.
TEMP 2 12 70.
TEMP 2 13 70.
TEMP 2 14 70.
TEMP 2 15 70.
TEMP 2 16 70.
TEMP 2 17 70.
TEMP 2 18 70.
TEMP 2 19 70.
TEMP 2 20 70.
TEMP 2 21 70.
TEMP 2 22 70.
TEMP 2 23 70.
TEMP 2 24 70.
TEMP 2 25 70.
TEMP 2 26 70.
TEMP 2 27 70.
TEMP 2 28 70.
TEMP 2 29 70.
TEMP 2 30 70.
TEMP 2 31 70.
TEMP 2 32 70.
TEMP 2 33 70.
TEMP 2 34 70.
TEMP 2 35 70.
TEMP 2 36 70.
TEMP 2 37 70.
TEMP 2 38 70.
TEMP 2 39 70.
TEMP 2 40 70.
TEMP 2 41 70.
TEMP 2 42 70.
TEMP 2 43 70.
TEMP 2 44 70.
TEMP 2 45 70.
TEMP 2 46 70.
TEMP 2 47 70.
TEMP 2 48 70.
TEMP 2 49 70.
TEMP 2 50 70.
TEMP 2 51 70.
TEMP 2 52 70.
TEMP 2 53 70.
TEMP 2 54 70.
TEMP 2 55 70.
TEMP 2 56 70.
TEMP 2 57 70.
TEMP 2 58 70.
TEMP 2 59 70.
TEMP 2 60 70.
TEMP 2 61 70.
TEMP 2 62 70.
TEMP 2 63 70.
TEMP 2 64 70.
TEMP 2 65 70.
TEMP 2 66 70.
TEMP 2 67 70.
TEMP 2 68 70.
TEMP 2 69 70.
TEMP 2 70 70.
TEMP 2 71 70.
TEMP 2 72 70.
TEMP 2 73 70.
TEMP 2 74 70.
TEMP 2 75 70.
TEMP 2 76 70.
TEMP 2 77 70.
TEMP 2 78 70.
TEMP 2 79 70.
TEMP 2 80 70.
TEMP 2 81 70.
TEMP 2 82 70.
TEMP 2 83 70.
TEMP 2 84 70.
TEMP 2 85 70.
TEMP 2 86 70.
TEMP 2 87 70.
TEMP 2 88 70.
TEMP 2 89 70.
TEMP 2 90 70.
TEMP 2 91 70.
TEMP 2 92 70.
TEMP 2 93 70.
TEMP 2 94 70.
TEMP 2 95 70.
TEMP 2 96 70.
TEMP 2 97 70.
TEMP 2 98 70.
TEMP 2 99 70.
TEMP 2 100 70.
TEMP 2 101 70.
TEMP 2 102 70.
TEMP 2 103 70.
TEMP 2 104 70.
TEMP 2 105 70.
TEMP 2 106 70.
TEMP 2 107 70.
TEMP 2 108 70.
TEMP 2 109 70.
TEMP 2 110 70.
TEMP 2 111 70.
TEMP 2 112 70.
TEMP 2 113 70.
TEMP 2 114 70.
TEMP 2 115 70.
TEMP 2 116 70.
TEMP 2 117 70.
TEMP 2 118 70.
TEMP 2 119 70.
TEMP 2 120 70.
TEMP 2 121 70.
TEMP 2 122 70.
TEMP 2 123 70.
TEMP 2 124 70.
TEMP 2 125 70.
TEMP 2 126 70.
TEMP 2 127 70.
TEMP 2 128 70.
TEMP 2 129 70.
TEMP 2 130 70.
TEMP 2 131 70.
TEMP 2 132 70.
TEMP 2 133 70.
TEMP 2 134 70.
TEMP 2 135 70.
TEMP 2 136 70.
TEMP 2 137 70.
TEMP 2 138 70.
TEMP 2 139 70.
TEMP 2 140 70.
TEMP 2 141 70.
TEMP 2 142 70.
TEMP 2 143 70.
TEMP 2 144 70.
TEMP 2 145 70.
TEMP 2 146 70.
TEMP 2 147 70.
TEMP 2 148 70.
TEMP 2 149 70.
TEMP 2 150 70.
TEMP 2 151 70.
TEMP 2 152 70.
TEMP 2 153 70.
TEMP 2 154 70.
TEMP 2 155 70.
TEMP 2 156 70.
TEMP 2 157 70.
TEMP 2 158 70.
TEMP 2 159 70.
TEMP 2 160 70.
TEMP 2 161 70.
TEMP 2 162 70.
TEMP 2 163 70.
TEMP 2 164 70.
TEMP 2 165 70.
TEMP 2 166 70.
TEMP 2 167 70.
TEMP 2 168 70.
TEMP 2 169 70.
TEMP 2 170 70.
TEMP 2 171 70.
TEMP 2 172 70.
TEMP 2 173 70.
TEMP 2 174 70.
TEMP 2 175 70.
TEMP 2 176 70.
TEMP 2 177 70.
TEMP 2 178 70.
TEMP 2 179 70.
TEMP 2 180 70.
TEMP 2 181 70.
TEMP 2 182 70.
TEMP 2 183 70.
TEMP 2 184 70.
TEMP 2 185 70.
TEMP 2 186 70.
TEMP 2 187 70.
TEMP 2 188 70.
TEMP 2 189 70.
TEMP 2 190 70.
TEMP 2 191 70.
TEMP 2 192 70.
TEMP 2 193 70.
TEMP 2 194 70.
TEMP 2 195 70.
TEMP 2 196 70.
TEMP 2 197 70.
TEMP 2 198 70.
TEMP 2 199 70.
TEMP 2 200 70.
TEMP 2 201 70.
TEMP 2 202 70.
TEMP 2 203 70.
TEMP 2 204 70.
TEMP 2 1 250.
TEMP 2 2 250.
TEMP 2 3 250.
TEMP 2 4 250.
TEMP 2 205 250.
TEMP 2 206 250.
TEMP 2 207 250.
TEMP 2 208 250.
GRID 1 0 0. 0. 0. 0
GRID 2 0 1. 0. 0. 0
GRID 3 0 1. 0. 1. 0
GRID 4 0 0. 0. 1. 0
GRID 5 0 0. .006 0. 0
GRID 6 0 1. .006 0. 0
GRID 7 0 1. .006 1. 0
GRID 8 0 0. .006 1. 0
GRID 9 0 0. .012 0. 0
GRID 10 0 1. .012 0. 0
GRID 11 0 1. .012 1. 0
GRID 12 0 0. .012 1. 0
GRID 13 0 0. .018 0. 0
GRID 14 0 1. .018 0. 0
GRID 15 0 1. .018 1. 0
GRID 16 0 0. .018 1. 0
GRID 17 0 0. .024 0. 0
GRID 18 0 1. .024 0. 0
GRID 19 0 1. .024 1. 0
GRID 20 0 0. .024 1. 0
GRID 21 0 0. .03 0. 0
GRID 22 0 1. .03 0. 0
GRID 23 0 1. .03 1. 0
GRID 24 0 0. .03 1. 0
GRID 25 0 0. .036 0. 0
GRID 26 0 1. .036 0. 0
GRID 27 0 1. .036 1. 0
GRID 28 0 0. .036 1. 0
GRID 29 0 0. .042 0. 0
GRID 30 0 1. .042 0. 0
GRID 31 0 1. .042 1. 0
GRID 32 0 0. .042 1. 0
GRID 33 0 0. .048 0. 0
GRID 34 0 1. .048 0. 0
GRID 35 0 1. .048 1. 0
GRID 36 0 0. .048 1. 0
GRID 37 0 0. .054 0. 0
GRID 38 0 1. .054 0. 0
GRID 39 0 1. .054 1. 0
GRID 40 0 0. .054 1. 0
GRID 41 0 0. .06 0. 0
GRID 42 0 1. .06 0. 0
GRID 43 0 1. .06 1. 0
GRID 44 0 0. .06 1. 0
GRID 45 0 0. .066 0. 0
GRID 46 0 1. .066 0. 0
GRID 47 0 1. .066 1. 0
GRID 48 0 0. .066 1. 0
GRID 49 0 0. .072 0. 0
GRID 50 0 1. .072 0. 0
GRID 51 0 1. .072 1. 0
GRID 52 0 0. .072 1. 0
GRID 53 0 0. .078 0. 0
GRID 54 0 1. .078 0. 0
GRID 55 0 1. .078 1. 0
GRID 56 0 0. .078 1. 0
GRID 57 0 0. .084 0. 0
GRID 58 0 1. .084 0. 0
GRID 59 0 1. .084 1. 0
GRID 60 0 0. .084 1. 0
GRID 61 0 0. .09 0. 0
GRID 62 0 1. .09 0. 0
GRID 63 0 1. .09 1. 0
GRID 64 0 0. .09 1. 0
GRID 65 0 0. .096 0. 0
GRID 66 0 1. .096 0. 0
GRID 67 0 1. .096 1. 0
GRID 68 0 0. .096 1. 0
GRID 69 0 0. .102 0. 0
GRID 70 0 1. .102 0. 0
GRID 71 0 1. .102 1. 0
GRID 72 0 0. .102 1. 0
GRID 73 0 0. .108 0. 0
GRID 74 0 1. .108 0. 0
GRID 75 0 1. .108 1. 0
GRID 76 0 0. .108 1. 0
GRID 77 0 0. .114 0. 0
GRID 78 0 1. .114 0. 0
GRID 79 0 1. .114 1. 0
GRID 80 0 0. .114 1. 0
GRID 81 0 0. .12 0. 0
GRID 82 0 1. .12 0. 0
GRID 83 0 1. .12 1. 0
GRID 84 0 0. .12 1. 0
GRID 85 0 0. .126 0. 0
GRID 86 0 1. .126 0. 0
GRID 87 0 1. .126 1. 0
GRID 88 0 0. .126 1. 0
GRID 89 0 0. .132 0. 0
GRID 90 0 1. .132 0. 0
GRID 91 0 1. .132 1. 0
GRID 92 0 0. .132 1. 0
GRID 93 0 0. .138 0. 0
GRID 94 0 1. .138 0. 0
GRID 95 0 1. .138 1. 0
GRID 96 0 0. .138 1. 0
GRID 97 0 0. .144 0. 0
GRID 98 0 1. .144 0. 0
GRID 99 0 1. .144 1. 0
GRID 100 0 0. .144 1. 0
GRID 101 0 0. .15 0. 0
GRID 102 0 1. .15 0. 0
GRID 103 0 1. .15 1. 0
GRID 104 0 0. .15 1. 0
GRID 105 0 0. .156 0. 0
GRID 106 0 1. .156 0. 0
GRID 107 0 1. .156 1. 0
GRID 108 0 0. .156 1. 0
GRID 109 0 0. .162 0. 0
GRID 110 0 1. .162 0. 0
GRID 111 0 1. .162 1. 0
GRID 112 0 0. .162 1. 0
GRID 113 0 0. .168 0. 0
GRID 114 0 1. .168 0. 0
GRID 115 0 1. .168 1. 0
GRID 116 0 0. .168 1. 0
GRID 117 0 0. .174 0. 0
GRID 118 0 1. .174 0. 0
GRID 119 0 1. .174 1. 0
GRID 120 0 0. .174 1. 0
GRID 121 0 0. .18 0. 0
GRID 122 0 1. .18 0. 0
GRID 123 0 1. .18 1. 0
GRID 124 0 0. .18 1. 0
GRID 125 0 0. .186 0. 0
GRID 126 0 1. .186 0. 0
GRID 127 0 1. .186 1. 0
GRID 128 0 0. .186 1. 0
GRID 129 0 0. .192 0. 0
GRID 130 0 1. .192 0. 0
GRID 131 0 1. .192 1. 0
GRID 132 0 0. .192 1. 0
GRID 133 0 0. .198 0. 0
GRID 134 0 1. .198 0. 0
GRID 135 0 1. .198 1. 0
GRID 136 0 0. .198 1. 0
GRID 137 0 0. .204 0. 0
GRID 138 0 1. .204 0. 0
GRID 139 0 1. .204 1. 0
GRID 140 0 0. .204 1. 0
GRID 141 0 0. .21 0. 0
GRID 142 0 1. .21 0. 0
GRID 143 0 1. .21 1. 0
GRID 144 0 0. .21 1. 0
GRID 145 0 0. .216 0. 0
GRID 146 0 1. .216 0. 0
GRID 147 0 1. .216 1. 0
GRID 148 0 0. .216 1. 0
GRID 149 0 0. .222 0. 0
GRID 150 0 1. .222 0. 0
GRID 151 0 1. .222 1. 0
GRID 152 0 0. .222 1. 0
GRID 153 0 0. .228 0. 0
GRID 154 0 1. .228 0. 0
GRID 155 0 1. .228 1. 0
GRID 156 0 0. .228 1. 0
GRID 157 0 0. .234 0. 0
GRID 158 0 1. .234 0. 0
GRID 159 0 1. .234 1. 0
GRID 160 0 0. .234 1. 0
GRID 161 0 0. .24 0. 0
GRID 162 0 1. .24 0. 0
GRID 163 0 1. .24 1. 0
GRID 164 0 0. .24 1. 0
GRID 165 0 0. .246 0. 0
GRID 166 0 1. .246 0. 0
GRID 167 0 1. .246 1. 0
GRID 168 0 0. .246 1. 0
GRID 169 0 0. .252 0. 0
GRID 170 0 1. .252 0. 0
GRID 171 0 1. .252 1. 0
GRID 172 0 0. .252 1. 0
GRID 173 0 0. .258 0. 0
GRID 174 0 1. .258 0. 0
GRID 175 0 1. .258 1. 0
GRID 176 0 0. .258 1. 0
GRID 177 0 0. .264 0. 0
GRID 178 0 1. .264 0. 0
GRID 179 0 1. .264 1. 0
GRID 180 0 0. .264 1. 0
GRID 181 0 0. .27 0. 0
GRID 182 0 1. .27 0. 0
GRID 183 0 1. .27 1. 0
GRID 184 0 0. .27 1. 0
GRID 185 0 0. .276 0. 0
GRID 186 0 1. .276 0. 0
GRID 187 0 1. .276 1. 0
GRID 188 0 0. .276 1. 0
GRID 189 0 0. .282 0. 0
GRID 190 0 1. .282 0. 0
GRID 191 0 1. .282 1. 0
GRID 192 0 0. .282 1. 0
GRID 193 0 0. .288 0. 0
GRID 194 0 1. .288 0. 0
GRID 195 0 1. .288 1. 0
GRID 196 0 0. .288 1. 0
GRID 197 0 0. .294 0. 0
GRID 198 0 1. .294 0. 0
GRID 199 0 1. .294 1. 0
GRID 200 0 0. .294 1. 0
GRID 201 0 0. .3 0. 0
GRID 202 0 1. .3 0. 0
GRID 203 0 1. .3 1. 0
GRID 204 0 0. .3 1. 0
GRID 205 0 0. .306 0. 0
GRID 206 0 1. .306 0. 0
GRID 207 0 1. .306 1. 0
GRID 208 0 0. .306 1. 0
CHEXA 1 3 9 10 11 12 5 6+
+ 7 8
CHEXA 2 2 13 14 15 16 9 10+
+ 11 12
CHEXA 3 2 17 18 19 20 13 14+
+ 15 16
CHEXA 4 3 21 22 23 24 17 18+
+ 19 20
CHEXA 5 2 25 26 27 28 21 22+
+ 23 24
CHEXA 6 2 29 30 31 32 25 26+
+ 27 28
CHEXA 7 3 33 34 35 36 29 30+
+ 31 32
CHEXA 8 2 37 38 39 40 33 34+
+ 35 36
CHEXA 9 2 41 42 43 44 37 38+
+ 39 40
CHEXA 10 3 45 46 47 48 41 42+
+ 43 44
CHEXA 11 2 49 50 51 52 45 46+
+ 47 48
CHEXA 12 2 53 54 55 56 49 50+
+ 51 52
CHEXA 13 3 57 58 59 60 53 54+
+ 55 56
CHEXA 14 2 61 62 63 64 57 58+
+ 59 60
CHEXA 15 2 65 66 67 68 61 62+
+ 63 64
CHEXA 16 3 69 70 71 72 65 66+
+ 67 68
CHEXA 17 2 73 74 75 76 69 70+
+ 71 72
CHEXA 18 2 77 78 79 80 73 74+
+ 75 76
CHEXA 19 3 81 82 83 84 77 78+
+ 79 80
CHEXA 20 2 85 86 87 88 81 82+
+ 83 84
CHEXA 21 2 89 90 91 92 85 86+
+ 87 88
CHEXA 22 3 93 94 95 96 89 90+
+ 91 92
CHEXA 23 2 97 98 99 100 93 94+
+ 95 96
CHEXA 24 2 101 102 103 104 97 98+
+ 99 100
CHEXA 25 3 105 106 107 108 101 102+
+ 103 104
CHEXA 26 2 109 110 111 112 105 106+
+ 107 108
CHEXA 27 2 113 114 115 116 109 110+
+ 111 112
CHEXA 28 3 117 118 119 120 113 114+
+ 115 116
CHEXA 29 2 121 122 123 124 117 118+
+ 119 120
CHEXA 30 2 125 126 127 128 121 122+
+ 123 124
CHEXA 31 3 129 130 131 132 125 126+
+ 127 128
CHEXA 32 2 133 134 135 136 129 130+
+ 131 132
CHEXA 33 2 137 138 139 140 133 134+
+ 135 136
CHEXA 34 3 141 142 143 144 137 138+
+ 139 140
CHEXA 35 2 145 146 147 148 141 142+
+ 143 144
CHEXA 36 2 149 150 151 152 145 146+
+ 147 148
CHEXA 37 3 153 154 155 156 149 150+
+ 151 152
CHEXA 38 2 157 158 159 160 153 154+
+ 155 156
CHEXA 39 2 161 162 163 164 157 158+
+ 159 160
CHEXA 40 3 165 166 167 168 161 162+
+ 163 164
CHEXA 41 2 169 170 171 172 165 166+
+ 167 168
CHEXA 42 2 173 174 175 176 169 170+
+ 171 172
CHEXA 43 3 177 178 179 180 173 174+
+ 175 176
CHEXA 44 2 181 182 183 184 177 178+
+ 179 180
CHEXA 45 2 185 186 187 188 181 182+
+ 183 184
CHEXA 46 3 189 190 191 192 185 186+
+ 187 188
CHEXA 47 2 193 194 195 196 189 190+
+ 191 192
CHEXA 48 2 197 198 199 200 193 194+
+ 195 196
CHEXA 49 3 201 202 203 204 197 198+
+ 199 200
CHEXA 50 5 5 6 7 8 1 2+
+ 3 4
CHEXA 51 4 205 206 207 208 201 202+
+ 203 204
ENDDATA 707054dc
