BOM Bubble stacking
BOM Bubble stacking
BOM Bubble stacking
Is there a way to stack bubbles horizontally, and vertically at the same time? I want to horizontally stack the components, and underneath stack the specific configuration. If there is such a way, I don't want the B.O.M. to contain the same detail as the component callout bubbles. Is this possible?
SW Professional 2014 SP 4.0 SW Electrical 2D/3D SP 3.0
64 bit SP1.0
Intel Xeon X(R) CPU 1603 0 @ 2.80 GHz
8.0 GB of RAM
NVIDIA Quadro 2000
RE: BOM Bubble stacking
Chris,
I'm sorry - I'm missing something...Does this tell me how to stack horizontally and vertically at the same time? - I know how to do either/or - but not both at the same time. Every time I click 'add to stack' and say whether I want the bubbles horizontal or vertical, it changes the entire stack, not just the present bubble.
64 bit SP1.0
8.0 GB of RAM
NVIDIA Quadro 2000
In the Feature Manager, change the Balloons per line. You might have to change the second line to text, in order to get the configs or maybe you could link them.
Dur! I knew it had to be something easy. 1000 blessings to you and your family.
