Electric motor-shaft
Hi, friends
I have a frame 364TCV G.E. electric motor and it has wear of material in the area of the bearing on the side seat attach. Wear is 0.018 "with respect to the unused side of the engine which is 2.756" what welding procedure should apply not to damage the winding of the motor.
What welding procedure can I do you?
thanks
thanks
