Amada FO3015 Cutting Stainless with Plastic coating
I was just asked if there is some code to use to make cutting plastic coated SS go smoother. I looked in books, but nothing is jumping out at me.
Bonus Question: Anyone use Glycol or synthetic chiller fluid in their Amada FO3015 system with a Fanuc C4000 Resonator? The Fanuc book recommends water with additives. Seems to me that Heat Transfer Fluids would be way better for a machine. We use Dowtherm SR-1 in our other machines. What are your choices and experiences with cooling systems?
"I am stuck on Band-Aid brand, 'cause they are stuck on me"
RE: Amada FO3015 Cutting Stainless with Plastic coating
They think what they are looking for is some code that has the head come down and do a small pre-etch to move the plastic away before it actually pierces. Our Controller is a 160i, If this is documented somewhere, I would like to know where so I can see what other goodies I may find.
http://www.eng-tips.com/viewthread.cfm?qid=264427
The solution for those searching is changing Macro M103 to M134 which had the head come partially down and do a quick circle out of focus to melt the plastic away before it pierced. This worked beautifully. The other suggestion by LASERNINJA™ we did not try was altering Macro 912 gas delay to "0". we shall keep that in our utility belt for now.
still curious about heat transfer fluid options and opinions.
On ours, that brings the nozzle to about 1" off material, quick shot and clears about 1/4" of the plastic. Then cut away.
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
