Exporting as STP files issue
I have problem when exporting my files as STP files.
When I view the STP file from Visualization MockUp or simply reopen it, the component name changes to the first 4 letters of MY name and then has a random set of numbers and letters after.
How do I make it so that it doesn't export out with my name in the components list?
Thanks.
- Kozen
RE: Exporting as STP files issue
Are you running the STEP translation from Native NX or from NX through Teamcenter?
Hey MASawtell,
I've ran it through both, and either way, it comes out with my name then a random set of numbers and letters.
I'm thinking it has something to do with my preferences? I'm not sure what to change to get my preferences back to normal, though.
- Kozen
The component name of the file I just translated has the EXACT same name as the file that gets placed into the Temp folder as shown in the above link to my JPG.
- Kozen
I only have a guess on this, but check your customer defaults to see if something is listed in there that adds the numbers to the file.
Hey Jerry,
I'm checking Customer Defaults -> Translators and looking at STEP203 and STEP214, and I can't seem to find anything different from coworker's NX programs.
I'm now checking the other settings, but so far, haven't found anything of note. I'll reply back if I find something or not.
- Kozen
Kozen, please check the settings in your external STEP Translator when you get a chance
I've restarted my computer and it seems to have fixed the problem (somehow).
I'm going to check my external STEP Translator now. Thanks.
- Kozen
I just found out that when I go to File > Export > STEP203/STEP214 (either one) > Data Export and choose ENTIRE PART, the name of the components come out fine. It won't have my name and a random set of numbers and letters. But when I choose SELECTED OBJECTS instead of ENTIRE PART, I get my name and a random set of numbers and letters as the component's name.
Pretty annoying bug.
- Kozen
When you select things for export, you can only pick solid bodies and not components ?
the component has a proper name but the solid has not.
What version of NX are you running ?
Tomas
Hey Toost,
I'm using NX8. If I choose to select the objects that I want to export as STP, I usually choose Curves, Surfaces and Solids. But whenever I do this, the naming of the components in the STP file gets messed up.
- Kozen
Sorry, that was for exporting the ENTIRE PART. Exporting using the ENTIRE PART feature doesn't mess up the name.
But when I want to SELECT OBJECTS to export, I usually highlight the entire model, and when exported, the name of the component in the STP gets messed up.
- Kozen
To clarify, I go to File > Export > STEP203/STEP214 (either one) > Data to Export > Under Model Data, I choose the SELECTED OBJECTS function, where use Select All to select the entire model.
Doing this gives me an STP with a component that shows my name and a random set of numbers and letters.
Sorry for the confusion.
- Kozen
I have a feeling that you will need to call GTAC on this one.
