Audio through a transformer.
Good Morning All
I am Trying to use my smartphone headset (with mic) to plug work with my landline phone.
So I created an RJ9 to 4pin aux jack converter. In theory it was all meant to be so simply, just a walk in the park...
But! You can't connect the RJ9 Mic and loudspeaker *ground together... It shorts the phone...
So I separated the *grounds using a transformer I found in a power supply.
Solved the grounding problem and now I have an obnoxious buzzz on the line.
There is my story, here is my question:
Is this buzzz from the fact that it is a power supplies transformer? Would replacing it with an audio output transformer help?
* is not actual ground but the negative side of the Mic and the Loudspeaker.
RE: Audio through a transformer.
Since a telephone circuit can literally be miles of twisted pair hung on telephone poles approximately 10 - 12 feet below power lines that may be carrying 7200 volts or higher, each individual wire of the pair does pick up major amounts of electrical noise. BUT since the voice/data sent on the twisted pair is a differential signal, the noise cancels out, if and only if the electrical symmetry (or longitudinal balance) of the pair of wires is very high.
Any circuit connection on your end of the circuit that introduces any resistance, capacitance or inductance to ground that is not symmetrical across both wires will upset the entire circuit balance and you will experience a major increase in noise.
https://www.valuetronics.com/Manuals/wilcom_t207.P...
http://www.nhsignal.com/pdf/NH_Analyzer_0408.pdf
For example, I use a Panasonic KX-TG7641 DECT 6 wireless system in which each handset includes a headset jack... and I use that jack to connect a Heil headset that is also interconnected into other VHF & HF radio systems.
The base unit to handset connection is wireless so your connection to the handset jack will not affect the phone line itself since there is no metallic connection. And of course with the handset being wireless, if you need to move around while talking on the phone.. well that's the whole idea of the design.
One caveat, don't try to use this (or probably any such system) while the handset is sitting in the charging cradle, noise will be introduced.. but when the handset is out of the cradle during use, (as the design intended) it works perfectly.
http://www.amazon.com/Panasonic-KX-TG7642M-Bluetoo...
He mentioned "RJ9", not RJ11.
Glenn
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Dan - Owner
http://www.Hi-TecDesigns.com
Simplest solution is to hit eBay.
Thank you for all the replies, sorry about my absence.
@VE1BLL Tried that, unfortunately ebay couldn't supply what I wanted and I've invested to much money now to walk away.
@LiteYear The Smartphone jack (4 pin Aux) only has 1 ground, so Mic ground and speaker ground would have to be one, that's why I introduced the transformer.
@MacGyverS2000 & IRstuff I remember that horrible sound all to well, but this doesn't seem to be along those lines, the interference comes in even if I don't have the cellphone anywhere nearby.
@geekEE Agreed, that's why I hope an audio transformer will do the trick, but at the same time I don't want to spend more money on this and it doesn't work.
@DanEE 10:00 That is a simple idea that could of worked, but I don't want to buy a new phone for work. (if I had done that from the start, probably would of worked out cheaper)
@DanEE 9:37 Thank you for explaining the problem, this does make a lot more sense now. I get that I am disturbing the force and all that, but I really believed that the telephone would be able to isolate the line coming in from the audio going out. What if I added a buffer before the transformer. This would stop the transformer and everything afterwards from loading the telephones circuit.
@BrianG I have added a drawing.
An example search:
http://www.ebay.com/sch/i.html?_nkw=telephone+head...
Obviously I'm guessing here, so if you have some unique and particular requirements, then you may be correct that there's nothing suitable available. Good luck.
TTFN
