Error 9 - Rename File Error
thread801-126877: error cleaning frame section arrays - error no.9
I have the same problem as this previous thread that was closed. Does anyone know what is causing this error?
"Unable to complete operation 'RunAnalysis'! Error 9 Please save file under a different name.
The results seem to be correct; however, it seems to be buggy when displaying certain results (ie, when selecting a group to show only to report the joint loads, one joint in the group won't show, or sometimes the table function won't work so I'll rerun and then it'll work).
I've renamed the file and saved in many different locations.
Is this a problem with my model? Or a software corruption?
Thanks for your help,
Camille
Camille
